How to control tpi/stealthram system
Old Apr 6, 2010 | 10:05 PM
camarostylin's Avatar
so, I'm in Virginia and if anyone's ever been here before you know you can easily experience 3 seasons in 1 day. I really want to build an extreme 350 or 383, and I want it to run smooth for having a LARGE cam in it. If I stick with the 350 I wanna go with an LT4 hotcam, if I go with the 383 and a nice set of heads I wanna go with a .574/.580 and 274/280 duration comp cams setup with 2.08 intake valves and 210 AFR heads.
so I really need some fuel injection to make this car fun and comfortable to drive and reliable. Im SICK of my carbs. So what I'd like to do is buy a TPI setup, sell the intake with runners and then use some of that money to buy a used stealthram intake and fuel rail. My question is, how will I use the TPI computer to control such a system? or would I need to replace the ECU with an aftermarket one?? what's the cheapest and most reasonable way to get this done?
I really dont know much about computer control on high modded engines. any help would be appreciated
Old Apr 8, 2010 | 09:30 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: How to control tpi/stealthram system
I have this same exact question with my 383. Ill keep watch on this thread.
Old Apr 15, 2010 | 04:48 AM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Basically, you're just looking to do an intake swap. The factory ECM will run the new engine with some time spent tuning.
Old Apr 19, 2010 | 09:00 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
you'll eliminate egr, so you need the chip burned
Old Apr 19, 2010 | 09:23 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
take a peek at my setup I program my EEprom.. I installed a ZIF socket in the prom carrier
Old Apr 19, 2010 | 10:39 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Nice. I'd like to do that. Where did you get the parts?
Old Apr 20, 2010 | 06:09 PM
88gta3508's Avatar
Engine: 231 / 383
http://www.tunercat.com/ for programing easy to use
Bins to open your factory prom $19.00
there are free programs.. they are not as graphical <> harder to use
I do like tuner PRO!!! more features like changing your shift light indicator
http://xtronics.com/ flashing the atmel EEprom
http://www.digikey.com/?WT.term=atme...5522&WT.srch=1
atmel 27c256 EEproms.. I use 256 the speed is faster <> you only need 27c128
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
tglennon11
Sep 23, 2015 05:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
