Need reference number for 87 or 88 ECM
Old May 24, 2010 | 09:00 PM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
I swiched my third gen TPI from a 305 to a 350 dual fan, 700R4, MAF. I have been told I could use a stock 87 or 88 ECM (I am told that would be pre-VATS), however, I have no idea how to find the correct part or ECM numbers. I am short on experience with and could use some guidance. What should I expect to pay and should it be hard to find?
Old May 25, 2010 | 12:16 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Need reference number for 87 or 88 ECM
86-89 TPI motors (305 and 350) and a few others all used a 1227165 ECM. i've seen them go on ebay for $30 all the time. at that point, you'll need a 350 MEMCAL(that doesn't use VATS) or the ability to tune yourself. does your 91 not have VATS or did you already bypass it? if so, the bypass or working PASSKEY module should still work with the 86-89 ECM as well.
Old May 25, 2010 | 04:45 PM
The ECM is not actually for my 91. I put a third gen TPI in a 69 Impala. There is no VATS and I was hoping I could use an ECM and chip from a stock 87 or 88 350, MAF, 700R4. I believe these years were before VATS. I don't have chip burning access nor do I know much about it. If a stock chip would work, I'd use it. The only thing I'm not sure of is the temp of the fans and if they used two fans in 87 or 88.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 8, 2015 11:28 PM
