Coil Near Plug using wasted Spark Tech
Old May 30, 2010 | 11:03 PM
corvair_nut's Avatar
Car: 1968 Chev Corvair
Engine: 164 CID HO
Transmission: 2 Sp Powerglide
Axle/Gears: 3.55
OK... I might have hit the pipe a little hard tonight, but hear me out.
I have a 6 Cyl and use a 7747 ECM with DIS and it works like a charm, except for one thing...... PLUG WIRES.
My current thought is to use 6 small coils and wire the negative side to the the coils to the DIS controller and have them still fire in pairs (wasted spark) but have them coil near plug so I can do away with the long plug wires.
My concerns would be firing 2 coils at once instead of the 2 pole coils pull to much power and burn/overheat the driver/electronics out of the controller.
Does anyone know of the type of coil that would work or has anyone done it before?..... is it as dependable as DIS?
With the wasted spark and coil for each cyl, I could free up a lot of room to put it anywhere and might look pretty cool. The DIS controller has a + and - for each of the 3 coils and wanting to extend that to 6 coils.
Ted
Anderson, SC
68 Chev Corvair TBI/DIS
Old May 31, 2010 | 08:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Coil Near Plug using wasted Spark Tech
Can use six CDI units to take the load off the DIS module drivers, one for each coil. The other issue is that many GM DIS modules control dwell. They use the coil current to read the saturation level and adjust the dwell real time accordingly.
Without a coil of the proper load, the DIS module shuts down.
RBob.
evilstuie
Feb 28, 2016 03:33 PM
mddaniel
Sep 8, 2015 05:16 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
cstrobel65
Aug 15, 2015 10:19 AM
