looking for confirmation on esc location
Old Jun 8, 2010 | 01:01 AM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
hello first timer nice to meet you all. can anyone confirm if the esc is built in to the ecm in a 1991 camaro tpi or is it external as i cant locate it. i read some where that it was built in and i was getting a code 43. this car is a 305 car but has been converted to a 350 i also read when you convert that you have to replace the ecm and knock sensor which i thought could have been causing the code. i just replaced the knock and ecm with the ones for a 350 but i seem to have lost some performance and i still got my service engine light coming on anyone have any ideas? thanks for any input
Old Jun 8, 2010 | 08:19 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: looking for confirmation on esc location
My esc module was in the engine bay( before I moved it,,, follow the wire from the knock sensor and it will lead you right to it. IIRC mine was next to the brake booster on the firewall.
Old Jun 10, 2010 | 10:45 PM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
thanks for the reply i will try that and prove it once and for all
Old Jun 11, 2010 | 08:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ESC module on a '90 - '92 TPI cars is in the ECM. It is the white board on the MEMCAL. See the sticky above for a picture.
RBob.
Old Jun 11, 2010 | 11:46 PM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
thanks i definatly have the memcal one. i appreciate the assist
L98GTA87
Oct 19, 2015 10:43 PM
RGB2015
Sep 20, 2015 09:26 PM
89 formula TPI
Sep 7, 2015 11:06 AM
tonys91rs
Sep 2, 2015 07:07 PM
RyanJB
Sep 2, 2015 01:27 PM
