is there a good plug and play prom for 1991 z
Old Jun 10, 2010 | 11:30 PM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
hello all. i was wandering if there is a good plug and play prom for a 1991 z28. it is a 305 car that has been converted to a 350. i recently changed the knock sensor and ecm/prom to the ones specified for a 350 by chev. when i did this i lost a little bit of power(any idea why this would be?). also i just converted the car from an auto to a 5 speed. i'm looking for something to boost my performance. i did notice that there was a 4 wire plug that was in the automatic tranny that i don't have plugged into any thing now as i now have a t-5 with no place for it i don't know if that would affect anything. i set the timing to 0 deg base with the tach wire unplugged. thanks for any help
Old Jun 11, 2010 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: is there a good plug and play prom for 1991 z
The correct base timing for a TPI set up is 6* BTDC. That will get some of the power back.
The 4-wire onn the auto was for the TCC control. Lock up solenoid and 4th gear switch. Just wrap & tuck it up out of harms way.
The knock sensor torque spec is 11 to 14 ft/lb, not too tight. Any tighter and they become too sensitive. Reporting false knock which reduces the spark advance.
RBob.
Old Jun 11, 2010 | 08:30 AM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
thanks, excuse my ignorance what does BTDC stand for?
Old Jun 11, 2010 | 09:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Before Top Dead Center
RBob.
Old Jun 12, 2010 | 12:00 AM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
thanks a lot i reset the timing to 6 degrees advance and it seems to have returned my performance to where it was. i took it for a good 45 min test drive and my code 43 did not reoccur so i think i got it licked. i did get a code 32 for the egr valve which isnt to surprising as the previous owner pulled the smog pump assembly . would you happen to know how to eliminate the egr checking or how to prevent the code 32 from occuring. do i need a resister or something. also is there any negative effects performance wise to having this system removed
midge54
Sep 2, 2020 07:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
the_nikfive
Aug 11, 2015 02:46 AM
