Swapping from carb to FI
Old Jun 15, 2010 | 10:18 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I am toying around with the idea of fuel injecting the car one day. Not anytime soon, but one day. I have a few reasons for this. One of them is that I would like to build a bigger motor one day and I'm not sure if I want it to be NA, blown, or turbo. Unless I'm looking at it wrong, building a FI setup that could work with any of these setups is possible whereas a carbed setup would need a different carb for each one and a different manifold for each one. I also want to it be dead reliable and I have had a few issues, nothing much, with the carb. I'm also thinking that the fuel injection would help with some of the heat issues we have here in Florida as far as fuel in the carb getting too hot and boiling.
So my question is, is there a good factory ECM I could use, or would aftermarket be better? I'm not afraid of tuning and I am use to using computers. I dont know much about writing code, but I am willing to learn. All I really need control over is fuel, fuel pump, and spark control would be nice but not sure how to do this with a distributor.
Old Jun 15, 2010 | 11:58 AM
J.Prock's Avatar
Re: Swapping from carb to FI
I would also like to know this same stuff I just blew my carbed 355 after only one month of driving. It so I am planning on going back to TPI
Old Jun 15, 2010 | 12:14 PM
built91Z28's Avatar
If it matters I'm thinking a victor jr. efi manifold. I dont care about having an IAC either. I kinda like the rougher idle that just setting the throttle blade gives.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
