should i buy the dynamic efi EBL
Old Jul 31, 2010 | 05:12 AM
hasty88-and-89's Avatar
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
im reading the website but cant understand
how much will this cost at the end of installation from what i understand you have to modify the version that you order if anybody could clear up all the confusion im having that would be awesome
Old Jul 31, 2010 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: should i buy the dynamic efi EBL
I see an 89RS-5.0 in your mini-sig. If this is the intended vehicle and is still a TBI set up. All that is required is the EBL Flash self-install. That includes the board, end cover, documentation, serial cable and adapter, and software. The price of the self-install is listed on the EBL Flash product page.
Note that for self-install you or some one you know has to be good at soldering.
The other way to go is to purchase a complete EBL Flash ECM. This is everything listed above, along with an ECM with the EBL Flash board installed. The additional cost of the ECM and installation is listed on the purchasing page. Feel free to email about the pricing.
If you are running a MPFI set up, such as TPI, this is where the optional Port Mod is used. It changes the injector firing rate to the proper once per revolution. TBI is twice per revolution.
This is great for those having '85 - '89 TPI MAF cars. Change a few pins/wires in the harness connector, plumb/wire in a MAP sensor, and plug in the EBL Flash ECM.
If swapping a TBI to a TPI set up, easy to use. Just need to change the connectors under the hood for the TPS, and injectors. And sometimes the IAC connector. Then plug in an EBL Flash ECM (w/Port Mod), and turn the key.
Note that the EBL Flash ECM wil run the CCP and EGR valve, along with closed loop fueling for emissions. It won't run a twin solenoid AIR system (aka: smog pump).
RBob.
Old Aug 19, 2010 | 02:02 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
hey Rbob i just bought the flash from u guys, it should be here today, and i just found this thread, now this note that u posted, does it means that i get to get rid of the ugly smog pump in my car ??? if so, whats gonna happen to my cats, do i need to replace them with different ones since the A.I.R pump is not gonna be there anymore
Old Aug 19, 2010 | 07:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would leave all of the smog pump equipment in place. At the ECM harness connectors, pop pins C1 and C2 out of the connector. Protect them and fold them back out of the way. A piece of plastic soda straw over the terminal/wire taped in place will protect it.
This should put the AIR valves in divert mode. All air goes to the atmosphere.
Note that there is a terminal R&R how to on the dynamicefi.com site.
No need for a different cat, or needing to worry about the cat.
Air to the cat can be maintained via another method. The EBL ECM has a output that goes active when in PE/WOT mode. Need to figure out the valve activation between divert mode and air to cat mode.
Set up the valves so that air goes to the cat. Then when in PE/WOT mode, the ECM PE/WOT output switches the valves to divert mode.
This has air to the cat during normal driving and cruising. Then when in PE/WOT mode, the air is diverted to atmosphere.
RBob.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
