Wont flASH EBL
Old Aug 1, 2010 | 09:53 PM
L98wit's Avatar
Car: 91 rs
Engine: 350 tbi with EBL
Transmission: t56!
Axle/Gears: 2.733
Wont flASH EBL
my WUD wont flash my bin into the ecu. when i try to flash it says rx time out 2 (or) 1 TxSlInfo failed i am using a gigaware usb to serial cable. my laptop is a dell windows 7. ive searched these threads and downloaded the drivers advised with no luck. the wud display is getting information from the ecu (like when i press the gas. the computer recognizes the cable but it JUSt Wont flash. im ready to pull my hair out.
Old Aug 2, 2010 | 12:14 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Wont flASH EBL
I take it your laptop has no serial port?
Old Aug 2, 2010 | 07:43 AM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
Re: Wont flASH EBL
yep i just bought another cable and it wont work
Old Aug 2, 2010 | 08:44 AM
L98wit's Avatar
Car: 91 rs
Transmission: t56!
Axle/Gears: 2.733
Re: Wont flASH EBL
so i tried out the new cable from staples didn't work on my laptop but was lucky enough to find a phone cord long enough to reach from my driveway to my home computer so i could at least flash the car
Old Aug 2, 2010 | 10:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wont flASH EBL
Most likely your USB/Serial uses the Prolific ship set. Common issue among many others with those adapters.
Follow this link:
http://www.dynamicefi.com/USB2SerialSetup.php
If once you get to the advanced set up dialog there are FIFO sliders then it is a Prolific cable. Return them and get a cable that uses the latest FTDI chip set. Then for best performance lower the latency setting as shown in the link.
I smile when I read that you used a _long_ serial cable and it works. Can't do that with USB.
RBob.
RS Reaper
Oct 17, 2018 07:52 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
lewandom
Oct 1, 2015 08:15 AM
85Special
Sep 3, 2015 04:21 PM
