Convert O2 sensor mV to AF ratio
Old Aug 10, 2010 | 11:48 AM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Transmission: WC T-5
Axle/Gears: 2.77
Is there a way to use my O2 sensor output (mV) to determine what my air fuel ratio is?
Old Aug 10, 2010 | 12:36 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Convert O2 sensor mV to AF ratio
you can get a ROUGH estimate from it, when you're not in closed loop and the O2 is hot enough.
Old Aug 10, 2010 | 12:46 PM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Axle/Gears: 2.77
do you know conversion from mV to AF?
Old Aug 10, 2010 | 12:51 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
i use the hottest line, since i prefer to use heated O2s. using tunerpro to do the conversion for youis much easier though.
Old Aug 13, 2010 | 10:37 AM
woody80z28's Avatar
Car: 80 Camaro Z28
Engine: ~400hp Vortec 355ci
Transmission: T56 6-speed
Axle/Gears: 4.10 Moser 8.5" 10-bolt
Sweet! So how do you actually get Tunerpro to display the AFR rather than mV?
Old Aug 13, 2010 | 10:51 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
simpler than onemight expect....
just make a lookup table and make these entries:
a/d counts AFR
23 17
45 16
68 15.5
91 15
113 14.8
136 14.6
159 14.4
181 14.1
204 12.5
226 10.9
now, make a another value, have it use the O2 byte as a reference, send the data to the lookup table, and tunerpro will interpolate anything from a 17:1 to 10.9:1 AFR.
i have another chart for NBO2 to AFR, but i don't think it's very accurate.... says the crossover for 14.7:1 is 350mV.... i've always seen it somewhere between 450 and 550 mV...
also, those numbers are assuming an O2 conversion of X*4.42
Old Aug 13, 2010 | 05:38 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
wiggin, There are a handful of charts & conversion formulas you can use.
I would inquire as to what end you might find that info useful,
seriously.
Lots of us have worked this angle (some for fun) and with a very rare exception end up dependent on a WB for all the AFR's.
I'm not trying to blow you off, just the opposite.
Trying to save you some time.
The fact is NB o2's don't allow very accurate tuning far from 450mv.
So anything under 300mv or over 700mv is pretty useless.
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
PurelyPMD
May 5, 2016 04:57 PM
1992Z28!
Nov 19, 2015 07:33 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
