Faulty ECM?
Old Aug 11, 2010 | 10:13 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Faulty ECM?
Okay, I just performed an lb9 swap over my 2.8 v6, everything is installed, but for some reason, the injectors wont pulse to fire. I know the ecm is supposed to ground the injectors out, as 12v is supposed to be constant at pnk/blk wire. Also, when cranking, with my scan tool hooked up, no rpms are registered when it turns over, and it shows a desired idle of 3188?? im not finding any wiring problems, ive pretty much done everything but ecm replacement. Has anyone any advice?
Old Aug 11, 2010 | 10:19 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: Faulty ECM?
so u are using the same ecm for the v6??
Old Aug 11, 2010 | 10:24 PM
Re: Faulty ECM?
nope, its the 5.0 tpi ecm,
Old Aug 11, 2010 | 10:27 PM
juanillox8's Avatar
Car: TOO MANY
Re: Faulty ECM?
what car did it came from b/c it could be a vats problem, if the computer u installed has vats in it and ur key dsn't match the resistance ur injectors wont have any pulse
Old Aug 11, 2010 | 10:29 PM
Re: Faulty ECM?
the harness, ECM and tpi setup came from an 87 camaro, automatic. No vats there
Old Aug 11, 2010 | 10:32 PM
juanillox8's Avatar
Car: TOO MANY
Re: Faulty ECM?
is the distributor and module new or u are using the one that came with? check the ignition module, that will also prevent the injectors to pulse.
Old Aug 11, 2010 | 10:39 PM
Re: Faulty ECM?
the module and pickup coil are new, i traced the ecm reference wire out of the ICM purp/white, and it goes to ecm, with no shorts or problems , tested ICm and pickup coil with old school vantage meter, tested good
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
Jlanz55
Sep 29, 2015 08:55 AM
