87 305 prom to 350 vats prom
Old Sep 4, 2010 | 08:48 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Okay, i have an 87 350 tpi, and it is running on an 87 305 prom and injectors. I have had no problems and the car runs great. I originally had a 2.8, but swapped out for a 5.7. The ecm was bad, and changed that, which by the way came with a 350 prom, but it has vats. i was hoping to try a 350 prom to see if there was any real gain in performance. the problem is having vats, the 350 prom in my 87 computer will not fire the injectors. is there a way to get the vats 350 ecm to work on a car with no vats whatsoever
Glowsock
Jul 24, 2025 03:15 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
