Running very lean PLEASE HELP!!
Old Sep 21, 2010 | 10:23 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
Ok i just did an injector swap with bosch III's from southbay and now i am running even leaner than i was before. My BLM'S is now 160 as well as the integrator. i don't have any vacuum leaks or exhaust leaks. i am also getting a code 44 lean exhaust code. I think that it may be the fuel pump but i havn't checked it yet with a gauge all data values check out while datalogging is there anything else that i can look at?
Old Sep 23, 2010 | 05:52 PM
EagleMark's Avatar
Re: Running very lean PLEASE HELP!!
Fuel pressure!
Old Sep 23, 2010 | 07:49 PM
Car: 1990 Trans Am
I just had the fuel pressure checked and it was 37 psi at idle and went up to 39 with regulator vacuum hose disconnected so i am going to replace the pump does anybody have a recommendation as to what pump to get?
Old Sep 26, 2010 | 10:59 PM
triggerman454's Avatar
Car: 1991 Firebird, 1997 3000 GT
Engine: V6
Transmission: Auto... 5 speed manual
Axle/Gears: stock
If it's 37 at idle , it's not the pump. Just had issues with mine and it turned out to be the pump RELAY. Was 8 volts only getting to the pump.
Old Sep 27, 2010 | 11:30 AM
Car: 1990 Trans Am
the relay is new and i datalog with tunerpro rt and the fuel pump voltage is the same as battery 13.4 v when running
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Street Lethal
Aug 14, 2015 08:25 PM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
