1992 Camaro VAT System
Old Oct 31, 2010 | 06:10 PM
Fingerz04's Avatar
I have a 92 camaro rs and when i put key in ignition it shows the security light in dash but motor still starts and engine surges and had hard time running. does anyone know why this is happening and or how to fix the problem. thanks
Old Nov 1, 2010 | 06:53 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: 1992 Camaro VAT System
either replace the ignition switch that has the two wires feed off it which prob broke or.... bypass the vats. It can be done ny metering your resister in the key then purchasing the resistor that matches and wiring it in where the connection to the ignition switch would be...
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
