91 tbi help please?
Old Nov 14, 2010 | 02:01 PM
michaelpeerman's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
91 tbi help please?
I have what sounds like a simple question but cant seem to find the answer.
What are all things that can cause or tell my computer to kill the spark.
Old Nov 14, 2010 | 04:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 91 tbi help please?
i would first replace the ICM (ignition control module) the one inside the dist. cap . it's not un-common for them to take a dump . (mine left me on the side of the interstate for 6 1/2hrs. on a holiday weekend , talk about fun .) anyway be sure and coat bottom of new module with di-electric grease . it acts like a heat sink . good luck .
Old Nov 14, 2010 | 06:23 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
DO NOT use di-electric grease, rather the proper heat-transfer compound normally found packaged with the new module.
Old Nov 14, 2010 | 10:09 PM
UNCLE TOM's Avatar
please explain ? the last one i changed (from autozone) had a small packet of di-electric grease . ???????????????????
Old Nov 15, 2010 | 09:14 AM
xch3no2's Avatar
Transmission: TH400
Ahh, well see that is a common mis-understanding.
The product you used was not di-electric, or if it was, you can expect premature failure of the module.
Old Nov 25, 2010 | 02:20 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The stuff I use that I think is better than that silicone stuff is heat sink compound. Comes in a dinky little tube at Radio Shack. Does the job well and lasts. Just an idea for you to play with.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
