Electronic spark control?
Hey guys, My car keeps setting a code for the Electronic Spark Contol and It dies out in 5th gear pulling a hill. Where Is my ESC?? Its a 1991 Camaro Z28 with the F code 305 TPI engine.
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Electronic spark control?
Well, you shouldn't be lugging the car uphill in overdrive, but.....
According to All Data its block C1
Front LH Side Of Dash, On Relay Bracket
Car: check
Engine: check
Transmission: check
Usually the cause of a code 43 on that engine is the sensor or the sensor connector. The sensor is located in the block, passenger side, near the pan rail in front of the starter. Need to go under the car to get to it.
RBob.
