Ignition systems and DFI Gen7
Old Jan 19, 2011 | 11:01 AM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Since my 6AL blew up months ago ive been runnig stock HEI ignition. I want to put a new better then stock distributor, and ignition box in but not sure what is really compatable with the DFI setup. The 6AL almost fully cooked the DFI module. Fused one of the wires from the distributor module to the ecm. So what kind of setup is everyone else using. I want to be able to control all the ignition with the DFI, but want something that puts out a little more spark energy then the stock setup.
Also does anyone have a wiring diagram of how they set theres up?
Old Jan 19, 2011 | 12:17 PM
jonarotz's Avatar
Car: 91 Z28
Re: Ignition systems and DFI Gen7
You can run a 6A, 6AL, etc. It is pretty easy, you will just need to take your points trigger wire and run that to the Gen 7's blue wire on the ignition connector. If you need any more help with the hook up let me know.
Hotrodboba400
Dec 10, 2019 07:07 PM
e3pres
Sep 9, 2015 01:51 PM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
