Check engine light?
Old Jan 30, 2011 | 09:12 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Check engine light?
I had a check engine light when I first bought the car, and that was just because of the fact that there was no air temp sensor. I fixed that and the check engine light never came back on. Not too long ago, thecar overheated, and my uncle says I need a new thermostat because of that. Could this also cause my check engine light to come back on?
That is my problem...my light is back on, and I don't know why.
Old Jan 31, 2011 | 11:47 AM
EagleMark's Avatar
Re: Check engine light?
Pretty sure an oveheated engine means you need to check it!
Read my other post to you and you'll be well on your way to asking questions that the experianced knolagable guys here on the forum will answer...
Old Feb 2, 2011 | 02:10 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
If you check to see what code(s) are stored, that will tell you why the service engine light is on. Then there is no guessing back and forth
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
