chip question
Old Feb 3, 2011 | 08:23 AM
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
chip question
Hey I'm in the process of looking for a chip for my car that I modded, its a 88 pontiac gta trans am with the 5.7L engine. I put heads, cammed it, and put an intake manifold on it, plus a few more bolt ons and took emissions components off. I have the stock injectors on the car right now. My question is that if I order a chip do I need bigger injectors on the car or will the chip take care of the fuel delivery wit the stock ones? and also i kno i dont have all the power i should from the setup thats y im assuming the chip should bring out the performance from the new setup right?
thanx any info would really help.
Old Feb 4, 2011 | 10:29 AM
Ronny's Avatar
Re: chip question
see DIY Prom boards or if you want to order one take a look at tpichips.com.
In both cases you need to datalog engine to see state of tune before or after changes in bin. consider making or purchasing a ALDL cable for laptop.
Old Feb 4, 2011 | 10:51 AM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Re: chip question
With bigger cc heads and cam, I would go with 26-30lb injectors...
Old Feb 4, 2011 | 11:28 AM
TKR 88 GTA's Avatar
Engine: HSR 350
Re: chip question
Ok so wat exactly does that ALDL cable for the laptop do?
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
