ALDL Cable / scanner for my 1986 TPI?
Old Mar 6, 2011 | 06:53 PM
Looksthakill's Avatar
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hello,
I want to be able to take some readings from my ECM. Recently installed an HSR, etc. I want to do some tuning based on real-timing sensor readings, etc. Knock counts, etc.
Any recommendations? I don't want to spend a fortune, of course. How about an ALDL cable and a laptop with some of the free software that is out there?
Do share your recommendations/experience. THANKS!
Old Mar 29, 2011 | 01:51 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: ALDL Cable / scanner for my 1986 TPI?
Become very familiar with this... http://winaldl.joby.se/
I followed their directions for building an ALDL cable and I did it correctly on only my second try...after accidentally destroying the transistor the first time. All parts required were available at the local "shack of electronic stuff" and for less than $15 I had an ALDL cable.
The hardest part was finding an old laptop that still worked and had a RS232 port. ebay to the rescue...
Now I have a data logger that has already helped bring my car back to life, thank you WINALDL.
Old Mar 29, 2011 | 06:10 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Just to cover bases, the ALDL is only for reading... you'll need something else to tune / make changes in the ecm...
In a couple weeks, I'll be purchasing an EBL P4 Flash from www.dynamicefi.com
Rbob, owner & designer, is a member here and that thing is amazing
Rafael
Caspar
Jun 19, 2016 11:19 PM
Electro_X
Aug 19, 2015 07:59 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
