Flash programmer?
Old Mar 25, 2011 | 05:43 PM
xFeveredx's Avatar
Car: 1989 Pontiac Trans Am
Engine: 5.0 TPI LB9
Axle/Gears: 10-bolt 2.73
Flash programmer?
Would anyone happen to know if there is a flash programmer out there for a 1989 trans am, 305, tpi, auto? I was looking into chips and got told a flash programmer would be much better for gas mileage/power/ etc
any help or ideas would be much appreciated!
Old Mar 25, 2011 | 08:04 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Flash programmer?
Third gens use PROM chips. Flash reprogramable PCM's started in about 1995.
Old Mar 26, 2011 | 01:53 AM
xFeveredx's Avatar
Engine: 5.0 TPI LB9
well damn! im guessing theres only like two type, power or economy?
Old Mar 26, 2011 | 05:09 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No, you can also custom burn a PROM chip that will give you more variables. There are guys on this site that cab do it.
Old Mar 26, 2011 | 06:22 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I use the EBL flash http://dynamicefi.com/
Old Mar 26, 2011 | 06:52 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Please excuse my ignorance, I didn't know these old style computers could be converted to flashable.
Cool.
Old Mar 26, 2011 | 02:01 PM
xFeveredx's Avatar
Engine: 5.0 TPI LB9
Cool.
no worries! now as for this flash programmer, im going to hopefully assume it comes with simple instructions for a noob such as myself? mostly i just want to be able to use my car for work and play! i just want to switch it bw economy and power, would a chip possibly be cheaper and easier than a flash?
Old Mar 26, 2011 | 05:03 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Going the tune by chip route would be cheaper, possibly take longer, depending on how much you change. Both can have the same results in the end.
You can also buy EPROM emulators that take the place of the EPROM, and allow tuning while the engine is running, which the bin can then be programmed to an EPROM once you have the tune you want.
Old Mar 27, 2011 | 11:58 PM
xFeveredx's Avatar
Engine: 5.0 TPI LB9
so your saying i could get a chip, and program it so i get better gas mileage AND power, and not have to "tune as i go" basically?
honestly i dont know a whole lot about em so excuse my stupidity! haha
Old Mar 28, 2011 | 12:23 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Ignorance is not stupidity, many intelligent ppl suffer ignorance.
The best way to overcome ignorance is with in-depth study & hands-on experience.
I suggest you study, in depth, the tuning stickys posted on this forum.
Old Mar 29, 2011 | 01:29 AM
xFeveredx's Avatar
Engine: 5.0 TPI LB9
Thanks again guys for the help! ill look over some stickys here :P one more thing, can i buy pre-programmed chips? or is there somewhere i can download the bin files? not too sure about doing the tuning myself :/
Old Mar 29, 2011 | 04:18 PM
Ronny's Avatar
Go back to dynamicefi.com and read intro to tuning part 1 and part 2. If you are a beginner that is your best choice. If you car is stock you may in fact benefit from a so called performance chip as it may meet your needs. tpichips.com. I will guess they just lean out WOT and add some SA at WOT
junior419
Apr 7, 2025 11:35 AM
RS Reaper
Oct 17, 2018 07:52 PM
lewandom
Oct 1, 2015 08:15 AM
-=Z28=-
Sep 24, 2015 10:21 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
