how easy is it too detune a 7730 for cali smog?
Old Mar 11, 2011 | 01:30 PM
91formula-fbody's Avatar
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
I am wondering how hard it would be too detune my 7730 for california smog emisions, it has been tuned for performance and too work with 58mm throttle body, ported 083 heads with 2.02 1.60s, and a lt4 hot cam but i only have the 1.5 rockers on it right now? These crazy shops want alot of money, is it that hard or are they ripping me off?
Old Mar 11, 2011 | 01:35 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: how easy is it too detune a 7730 for cali smog?
If you are located in Southern California than Kevin91Z can do it for you. He is located in Orange, California.
Old Mar 11, 2011 | 01:36 PM
damn thats kinda far im in fresno, california
Old Mar 11, 2011 | 01:37 PM
i wonder how much he would charge though or whats a decent price?
Old Mar 11, 2011 | 07:10 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
will you be tested at wot?
Old Mar 11, 2011 | 07:24 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
The cam may be a problem also
Old Mar 11, 2011 | 10:47 PM
the cam shouldnt matter as long as it isnt burning too rich. no they do not test at wot
Old Mar 12, 2011 | 08:32 AM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
do u have your egr, smog pump,and correct exhaust?
Old Mar 12, 2011 | 09:40 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
The cam will matter, mine failed because of it.
And it's a small cam.
Old Mar 12, 2011 | 09:49 AM
Yes i have all the correct stuff installed for smog, just need it detuned because it was tuned for performance like the timming and air fuel ratio, the guy who was supose too tune it for smog said he has had bigger cams than that lt4 hotcam in vehicals and has been able too detune them for smog with no problem so im thinkin since i only have the 1.5 rockers on right now that it shojld pass easy with it detuned
Old Mar 12, 2011 | 09:56 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Sorry, you will see
Old Mar 12, 2011 | 10:00 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If your drivability tune is correct there is no need to change anything to pass smog.
After all, they test at 15 and 25 MPH.
If you fail it is not the cams fault, it's the tuner.
Kevin has tuned much larger cams than a LT4 hot cam and they pass the test just fine.
HTH
Old Mar 12, 2011 | 10:22 AM
dyno don, do you think it might be able too pass right now since it was tunned with hallowed out cats and i have just installed brand new ones so it will run leaner?
Old Mar 12, 2011 | 10:28 AM
Dyno Don's Avatar
Adding cats won't make it leaner, it will clean up the pollutants.
However, if it is running rich down low, it will ruin the new cats in time.
The biggest killer to a cat is raw fuel, after all, it is just an afterburner, it burns up any fuel that didn't get burned in the combustion process.
Old Mar 12, 2011 | 10:34 AM
ok cool ty for the info, when he did the tune he kept the air fuel ratio at about 15.0 im pretty possitive he didnt want it running too rich because i had just had the motor built and diddnt want it too flood the motor because the rings wouldnt seat properly
Old Mar 12, 2011 | 10:39 AM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
when they were testing in ohio... they tested at all different speeds...I made sure I drove the car for app. 30 min and left it running before the test.
Old Mar 12, 2011 | 10:41 AM
cool ill definitly try that before i go
Old Mar 12, 2011 | 03:23 PM
Just took a chance and went too smog the car and it passed with flying colors
Old Mar 12, 2011 | 07:50 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Dam how do you guys pass, my cam has a big lope to it as soon as they heard
that they said no. They said bring it back when it's stock
Old Mar 12, 2011 | 10:14 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
very nice
jaridjohn
Oct 5, 2015 07:01 AM
3.8TransAM
Oct 1, 2015 07:47 PM
