Wont Start
Old Apr 13, 2011 | 08:14 PM
jwoodworth90's Avatar
Wont Start
Swapped tpi motor out of my 85 z28 to my 84rs. Car will not start checked all connections and ECM is getting power, added second fuse block for fuel injectors. Checked resistance on injectors and get 16.5 ohms across all 8 and 4.5 on the Cold start. Miss placed the Vss buffer box during the swap will this cause the car not to start? I just ordered one tonight also the tach is not working. Replaced ECM and get the same result. Any help is appreciated!
Forgot to mention the Tach does not work I believe this is related to my issue the most
Old Apr 15, 2011 | 12:19 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: Wont Start
The VSS buffer won't keep the car from starting. What is the fuel pressure at the fuel rail? For a TPI, it should be 42-47 psi.
Old Apr 15, 2011 | 11:23 AM
Re: Wont Start
It is at 45PSI
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
