number of cylinders, 192?
Old Apr 21, 2011 | 10:28 AM
dougbyrd82's Avatar
using tuner pro and i dont quite understand number of cyilinders being 192, is this related to timing or somthing similar? engine is a 90 3.1L V6.
Old Apr 21, 2011 | 11:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: number of cylinders, 192?
Originally Posted by dougbyrd82
using tuner pro and i don't quite understand number of cylinders being 192, is this related to timing or something similar? engine is a 90 3.1L V6.
It is because of how the ECM firmware uses that value. The value 192 is 3/4's of the value 256. With 256 being the proper value to use when it is an 8-cylinder. Although, we can't store the value 256 as a single byte of data.
In the cal, an 8-cyl is set to the value of 0, which lets the firmware know to not do the multiply/divide.
A 4-cylinder uses 128, which is 1/2 of the 8-cylinder value (half the number of cylinders).
This value is used in the conversion of SA from degrees to a time based value. So it is important to have it correct. Has to do with the amount of crank rotation between spark plug firings.
RBob.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
codeysabatini
Nov 10, 2015 04:07 PM
lethaldomestics
Sep 21, 2015 01:18 PM
Springster
Sep 13, 2015 01:38 PM
