Mr. Gasket Performance Chip
Car: 1987 Camaro IROC-Z
Engine: LB9
I was under my dash looking for some antenna wiring when I got the bright idea to pull down the ECM and take a look at what chip was inside it as I've recently purchased the car and was not familiar with this particular one. To my suprize I had this inside looking back at me:
It pulled right off and revealed the eprom.
Overall the car seems to run better without it, I'm guessing this was just some 80s/90s snake oil product as I cannot imagine how it worked with fitting over the original eprom
For reference it is a LB9/700r4 iroc.
anyone ever seen this thing?
Car: check
Engine: check
Transmission: check
Re: Mr. Gasket Performance Chip
Wow, whom-ever did that didn't know what they were doing. Not only that but it appears to be a chip for a C3 ECM. This is due to it being in the RN holder. Does the MrGasket chip have 4 less pins then the stock chip (24 vs 28)?
Note that ACXT is the correct calibration for your car. So that is a good sign.
RBob.
RBob.
Car: 1985 IROC-Z28
Engine: LB9
LOL, that is a first for me.
i wonder if someone had a 85 w/LB9 and decided to plug their chip into their newer car however they could.
i never knew Mr Gasket was in the chip market to begin with.
Engine: LB9
I just checked the Mr. Gasket chip, it does have 24 pins vs the chip in the car having 28. Guess it was just there for decoration.
numbers on the bottom of it read 2S181A-CU
Transmission: 5-speed/T-5
That's funny.
Gives new meaning to the term "Piggy back." lol
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
