What to do about Computer due to aftermarket cam?
Old Jun 12, 2011 | 12:33 PM
Rcaldw9's Avatar
Car: 1987 Red GTA Trans Am
I bought an 87 GTA Trans Am from a guy and he put this cam in the car
http://www.compcams.com/Company/CC/c...x?csid=73&sb=2
The timing is off on the car and I don't think it will let me adjust the timing due to the computer thinking there is a stock cam in the car. Does this sound right? What do I do about the computer?
I'm new to this kind of stuff, not extremely knowledgeable about it. Any help is appreciated
Old Jun 13, 2011 | 08:40 AM
EagleMark's Avatar
Re: What to do about Computer due to aftermarket cam?
If you have no mechanical skills to set timing then I would suggest maybe haveing someone tune the car. Tuning chips is in the stickys on top of this forum, the Prom forum and TBI forum.
There is a wire, usually brown with white stripe that has a disconnect in it. You disconnect this wire and set timing on distributor like when cars had carburators. But with that cam I doubt stock idle timing is going to be usful. That cam is going to require major tuning the paremeters in the ECM.
Old Jun 14, 2011 | 04:29 PM
Ronny's Avatar
I think I would leave the timing stock for now. Rather I would work on the fueling. Fueling table needs to be addressed as the VE curve of engine has been changed. Invest in a ALDL cable, download datalogging software of your choice, and run some datalogs. Then make changes in fueling as needed. See stickies as suggested.
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
Bryan F
Aug 18, 2015 02:28 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
