Does the ECM monitor the temperature sensor?
Old Jul 16, 2011 | 12:11 AM
89Kicker_IROC-Z's Avatar
Car: 89' IROC-Z
Engine: HSR B2L 350ci w/LT4 hotcam and AFR 195's
Transmission: Transgo'd 700R w/Yank 2800
Axle/Gears: 9 Bolt, 3.45
Hey guys, my oem temp gauge is broken for the 4th time. I bought a new autometer gauge and I'm mounting it into my pillar pod. I wanted to run the sending unit right into the head like stock. If I remove the stock stuff, will this mess something up? I didn't think the ecm monitored the sending unit but ran across a thread last night saying that it might. If thats the case who knows why my car is acting up because I think my header fried the entire oem sending unit anyway. Car seems to run decent but it overheats.
Steve
Old Jul 16, 2011 | 09:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Does the ECM monitor the temperature sensor?
The ECM doesn't have anything to do with the dash temperature gauge. The ECM uses the coolant temperature sensor in the front of the intake manifold. Has two wires to it (yel&blk).
The dash gauge uses the sender that is in the drivers side (left) cylinder head.
RBob.
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
the 1 wire temp sensor? it's only for the guages, the ECM has a seperate 2-wire sensor.
Old Jul 17, 2011 | 12:43 AM
Car: 89' IROC-Z
Thanks guys, I'm going to try and run the new sensor into the head like stock
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
skeltor
Feb 2, 2016 10:37 AM
FormulasOnly
Sep 10, 2015 09:07 PM
willyjoejr
Sep 3, 2015 09:26 AM
