165 swap, problems
Old Jul 15, 2011 | 06:09 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
165 swap, problems
swapped from an 870 to a 165 and now the car won't crank, also the fan kicks on with ignition power, anyone know what that means??
Old Jul 18, 2011 | 01:55 PM
Engine: 3.8, 3.4
Re: 165 swap, problems
/bump, someone has to have a theory..or some tips on how to go about diagnosing it..
Old Jul 18, 2011 | 05:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Do you mean that the starter won't rotate the engine? The ECM doesn't have anything to do with that. Open the drivers door and observe the dome light.
Hit the starter, if the dome light goes out then either the battery is dead or the fusible links at the starter are going bad.
RBob.
Old Jul 18, 2011 | 05:43 PM
Engine: 3.8, 3.4
I didn't think it did, but its a hell of a coincidence, battery was being jumped at the time(battery is fine, but from sitting low lost its charge), and fusible links should be good as well.
A buddy suggested NSS, if that can actually keep the starter from cranking(thought it only did this in gears other than neutral and park, and would only do so if connected) then that's probably the problem, since my B&M shifter isn't 100% integrated as of yet(still need to track down the 4-40 screws for the reverse light and NSS.
Old Jul 19, 2011 | 07:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the NSS will prevent the starter from running. This is to prevent the vehicle from being started while in drive or reverse.
The other switch in a P/N input to the ECM. Ground for P/N, open for in drive. The ECM uses it for which idle speed to use, and to bump the IAC when the shifter is moved to an 'in gear' position.
RBob.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
sreZ28
Aug 14, 2015 07:48 PM
