sd tuned cars question.
Old Jul 18, 2011 | 05:31 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Just curious really my 92 z28 is of course a sd tuned car no maf. My question is with a mafless setup will the car recognize when I do bolt ons and air changes like a maf setup or wouldi constantly have to retune it for every mod ? I noticed when I redid my exhaust today that it had a 2 1/4 cat I pipe and flowmaster it always smelled kinda rich and even worse when I cleaned out the cat. Well now its got a new 3in magnaflow cat and 3in magnaflow catback it pulls much smoother and has no fuel smell hardly at all. I haven't checked my timing yetto see where its at the idle is right at 700 and I run 93 octaine non ethenol have no pinging and such. I know my 03 yukon with 5.3 is maf and when I first got it and still ran 87 gas I put a 4in cai on it and the first trip out under wot it pinged and valves chattered but after a few days of normal driving it pulled like a raped ape its been tuned for 93 now and has full boltons but when I did that intake I noticed the biggest pcm compensation.
Old Jul 19, 2011 | 11:29 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: sd tuned cars question.
depends what bolt-ons you're talking about.
CAI? no
headers? yes
think of it this way: if it might change the actual volumetric efficiency of the engine, then a retune would be advised. otherwise, a different amount of airflow is entering the engine than the ECM is expecting, and will cause rich/lean spots unless corrected.
Old Jul 19, 2011 | 11:54 AM
Screamin86's Avatar
so basicly if i get to the point where i add headers and upgrade the air box i should retune since i will be both pushing more air in and pushing out. the whole efi game is new to me especialy tpi lol.
Old Jul 19, 2011 | 11:57 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
well, headers will change the amount of air flowing into/out of the engine at any given RPM and MAP point, which means your fueling won't be correct until the VE table is dealt with.
a cold air intake would just allow cooler air into the engine, not a different amount, and the IAT sensor will correct for that.
stuff like that.
Old Jul 19, 2011 | 01:04 PM
Screamin86's Avatar
alright. guess ill eventaly looking into learning tuning lol.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Thirim
Aug 13, 2015 03:09 PM
