IAC Valve
Old Aug 14, 2011 | 12:54 PM
WilliamsJ91's Avatar
IAC Valve
My 91 RS 3.1 has a code coming up as the IAC Valve. Before I replace this, does the dealer have to set it or does this valve already automatically set its own spec?
Old Aug 15, 2011 | 12:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: IAC Valve
Once you replace the IAC do an idle learn procedure. A search of the V6 board using my name as the poster and "idle + learn" for the search string will bring it up.
RBob.
Old Aug 15, 2011 | 02:47 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: IAC Valve
fwd 2.8 & 3.1 multi's used to have to do the same thing.
eng. warm,a/c off --- 7 min in drive,3 min in park,5 min in drive.
92firebirdguy
Sep 1, 2016 07:53 AM
sandman92084
Sep 12, 2015 10:27 PM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
