540BBC With a 7730
Old Aug 18, 2011 | 04:52 PM
BB72Camaro's Avatar
540BBC With a 7730
I am running a 540" BBC in my 72 Camaro and using a 7730 ECM with the AXCS memcal. I am using a Holley EFI intake and a Holley throttle body. I have the engine making good peak power on the dyno but would like to do some drivabilty tuning.
I am using the tunerpro software currently and have read that you can tie the analog output of an LC-1 into a pin on the 7730 and data-log wide band simultaneously with everything else.
I have looked for step by step instructions for this but have not found any.
I need to know what pin the LC-1 output goes to and what .xdf and .adx files to use.
Also what else is required to make this work?
Thanks in advance for the help.
-Adam
Old Aug 18, 2011 | 11:49 PM
AmorgetRS's Avatar
Re: 540BBC With a 7730
https://www.thirdgen.org/forums/diy-...my-lc-1-a.html
This thread might answer your questions
Old Aug 19, 2011 | 12:00 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
That thread relates to the S_AUJP V4 usage of the WB.
Here are a couple describing how to do it with std $8D bins and patches.
This is a good discussion on how it all came together for the S_AUJP bin.
https://www.thirdgen.org/forums/diy-...-using-lc.html
There is another where Craig Moates just brought the signal into MAP2 and scaled it in the logger. Works fine that way, I just can't locate the thread.
Patching:
https://www.thirdgen.org/forums/diy-...atamaster.html
Seach on "MAP2" in the DIY-Prom board and you'll get buried in info
HTH
Old Aug 20, 2011 | 10:46 PM
BB72Camaro's Avatar
Is there a way to patch my bin that I am using, or would i be better off changing the calibration on a bin that is already patched?
BWilcox
Sep 20, 2015 12:19 PM
mddaniel
Sep 8, 2015 05:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
LBSZ28BLOWN
Jun 12, 2002 03:29 PM
HighHopes85
Jun 8, 2001 05:21 PM
