sensors comparrision from 87 compared to a 92
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
have a 92 block and soon will have a 87 tpi on her
going to have a 87 ecm and wiring harness nwas wonderin wat is the difference int these wire harness excluding mafs and speed density
sensor and stuff like that thanks
just be great to see if i could use this wiring harness
Car: 92 firebird
Re: sensors comparrision from 87 compared to a 92
305 tbi
going to tpi from a 87 with its ecm and wireing harness just wondering if theres a difference in sensors
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Yes there is a difference in sensors
Car: 92 firebird
ok so any way to use the 87 wire harness and for the sensor i need mix the up with the 92 wire just split em and addd them?? just curious
efiguy
Sep 27, 2015 01:30 PM
