Wiring EBL Flash To TPI Injectors (PORT MOD)
Old Nov 11, 2011 | 08:29 PM
89377STROKER's Avatar
Hi, just wondering how i have to go about wiring my EBL Flash with TBI Wiring Harness to a TPI Intake and injectors to run in batch firing mode with 8 injectors. I know the PORT Mod is needed to do this but more concerned with the injector wiring... Any pics of anyones self made harness or instructions on the swap would be awsome. Im working on a test bench for a future project to swap a TPI injection with a vortec style lower intake for a swap onto a 98 vortec motor...Thanks
Old Nov 12, 2011 | 09:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wiring EBL Flash To TPI Injectors (PORT MOD)
Wire four injectors in parallel on each driver. Usually need to extend the IAC & TPS wires and sometimes install the proper connectors for each.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
mx127
Aug 10, 2015 08:13 AM
