ECM LOCATION ON 89 FIRBIRD
Old Dec 5, 2011 | 04:47 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
was wondering were exactly the ecm is located i took the kickpanel off on the passenger side and ther was a black box was wondering if the ecm is located inside the box and how to remove that thanks
Old Dec 5, 2011 | 05:01 PM
Twin_Turbo's Avatar
Re: ECM LOCATION ON 89 FIRBIRD
pass side behind dash. Take off the knee pad below the dash, the screws to get to it are behind it. It's mounted straight up on the right side
Old Dec 5, 2011 | 05:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
That black box you saw was the vats module.
Old Dec 5, 2011 | 06:23 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
it was a big black box with three screw do i need to remove that or is the ecm behind that
Old Dec 5, 2011 | 06:32 PM
Engine: Lb9
Transmission: M20
the ecm may be black if its remanufactured usually not painted aluminum it has two 7mm screws holding its mounting bracket it it mounted horizontal between the passenger dash speaker and dash support brace.
Old Dec 5, 2011 | 07:17 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
this definitly not the ecm it is a plastic box i took the screw out but seem to still have problems getting it loose i will look later tonight and see if i can find it thaks
skeltor
Feb 2, 2016 10:37 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Jlanz55
Sep 8, 2015 11:28 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
