Code Scanner
Old Feb 4, 2012 | 11:49 PM
BT85's Avatar
Car: 85 Camaro Z28
Code Scanner
Hey guys I want to get a code scanner for my 1985 z28. My check engine light comes on every once in a while and the scanner is also just something to have. would this be the right one and if not can you suggest one? Thanks
http://www.summitracing.com/parts/ANM-CP9001/
Old Feb 4, 2012 | 11:53 PM
BT85's Avatar
Car: 85 Camaro Z28
Re: Code Scanner
and what OBD would I need?
Old Feb 5, 2012 | 07:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Code Scanner
OBD1, and that is an expensive paper-clip.
Find the ALDL connector and short pins A & B together. Key-on, engine-off and watch the dash SES/CEL light. It will blink out any stored codes. Code 12 will be the first code and is to be expected.
RBob.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
