86 ta fuse box wiring
Old Mar 21, 2012 | 01:27 PM
hoosierfan's Avatar
can someone please tell me the color of the wire for the fuel pump fuse at the fuse box.i bought this car(86 trans am 305 tpi) and will run if you spray gas into it but the fuel pump will not come on.the fuse and wire at the fuse box is missing.20 amp fuse but what color is the wire..there is like a million wires and might help if i could at least narrow down the color.thanks
Old Mar 21, 2012 | 02:33 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 86 ta fuse box wiring
Doesn't appear to need a fuse in the fuse box for the fuel pump. Probably why it is empty.
Power to the fuel pump relay is from the orange wire that runs from the battery, through an in-line 20 amp fuse, then on to the ECM & fuel pump relay.
This wire runs along the passenger side fender under the hood. Do a key-on, engine-off and look for the SES/CEL light. If it doesn't light up then either that fuse is popped or the bulb is missing.
RBob.
Old Mar 21, 2012 | 02:51 PM
hoosierfan's Avatar
i have tried what you suggested but the fuel pump will not come on at all and the gas guage doesnt work either.the hayes manual i have says theres supposed to be a fuel pump fuse in the fuse block second from left beside the ecm fuse and directly above the fuel injector fuses.the pump should prime when you turn key on but it doesnt.when i turn the key on i hear the relay click so im assuming that its working.i will keep looking and i would settle for the pump to be wired direct at this point.maybe time to go to a carb.thanks.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
stalkier
Aug 13, 2015 12:59 PM
