accel dfi 6
Old Mar 29, 2012 | 06:57 PM
David Brown's Avatar
Car: 1982 firebird. gale banks gt
Engine: Gale Banks Twin Turbo
Transmission: ZF 6 speed
Axle/Gears: ford 9 inch 3.50
accel dfi 6
I have an accel dfi 6 and no way to look at sensors or data. i do not have a program or cable. can anyone help? should i switch to a thrustmaster or dfi 7? or is my dfi 6 still a good setup?
Old Mar 30, 2012 | 10:51 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: accel dfi 6
have you contacted prestolite performance ?
Old Mar 30, 2012 | 08:26 PM
Re: accel dfi 6
Yes they can get me a cable but i would need a computer that runs dos 3. I was hoping that someone had a setup already.
Old Mar 30, 2012 | 09:01 PM
efiguy's Avatar
Re: accel dfi 6
Correct, and that will be hard to find.
The Gen 6 was ahead of it's time, For what it was, they worked pretty well.
But the new Thruster is light years ahead of that Gen 6. I'm an Accel EMIC, I think there's a guy in Tampa Fl that still does Gen 6's, I'll see if I can get some info for you.
Old Mar 30, 2012 | 10:09 PM
DIGGLER's Avatar
Re: accel dfi 6
my car came with a gen 6 and variable injector controller, which was an aluminum board with 8 ***** on it. you could vary the duty cycle on each of the injectors with it. sold it not long after i got the car.
i would just buy an old laptop off of ebay or something and run it.
Old Apr 2, 2012 | 08:30 PM
Re: accel dfi 6
I would consider changing to a new system. accel? fast? big stuff? holley?
any thoughts
Old Apr 2, 2012 | 08:36 PM
efiguy's Avatar
Re: accel dfi 6
any thoughts
If you're going to drive the car then Accel would be the best. If its more drag then the bs3 would probably be the best.
I just helped someone "tune" a self tuning FAST XFI, it's over on lateral g. So much for the self tuning stuff.
Fanatic1074
Oct 3, 2022 05:57 AM
WejaZ28
Oct 3, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
