Wiring Harness Help
Old Mar 30, 2012 | 12:04 AM
crimsoncomedian's Avatar
Wiring Harness Help
Need to know if this setup that I pulled with my 2003 5.3 from a silverado will work for a '92 Camaro swap. I know I will need (or want) to remove all the extra not needed wires. But will this ECM and harness actually work before I start the reworking?
Attached Thumbnails Wiring Harness Help-20120313_1433392.jpg   Wiring Harness Help-20120327_1441062.jpg   Wiring Harness Help-20120327_1441262.jpg
Old Mar 30, 2012 | 12:22 AM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: Wiring Harness Help
its should work fine, I'm using the same harness. The pins are similar to the red/blue harness. You will have to change the injector connectors to car ones, and add pins for the iac and tps, as your harness is drive by wire. I used pockets write up as a guide
https://www.thirdgen.org/forums/ltx-...ml#post4305264
Old Mar 30, 2012 | 12:23 AM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
