Prosport EVO Wideband Digital Air Fuel Ratio kit
Old Apr 5, 2012 | 11:30 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Axle/Gears: 4gen 3.23 PBR
Will this wideband air /fuel ratio kit work with EBL? I plan in next 2 months to buy EBL and trying also to fill my a-pillar gauge pod with some gauges.
Another question is do i need this to tune motor is it worth spending $200 on it.
I could not find any info on who is running wideband with EBL.
http://prosportgauges.com/wideband-a...t-Amber-2.aspx
Old Apr 6, 2012 | 07:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Prosport EVO Wideband Digital Air Fuel Ratio kit
With the output for data logging it will work with the EBL. They don't state whether that output is linear or not, although in this day & age it should be. I don't see the instruction manual on line, maybe you can get them to email it to you or ask them if the data logging output is linear.
Lots of folks using a WB with the EBL systems.
RBob.
Old Apr 6, 2012 | 12:58 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
I emailed them and here is the answer "The data output is designed to be tied into the cars computer".what else I can ask to make sure it will be working with EBL.
Old Apr 6, 2012 | 01:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is a rather bogus response.
Ask them what the conversion is from the output voltage to the reported AFR.
IOW: if the output voltage is currently at 1.6 volts, what is the AFR?
RBob.
Old Apr 6, 2012 | 02:01 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Their respond "There is 2, we have a 0-5v and a 0-1v".Will this work ?
Old Apr 6, 2012 | 02:48 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
a wideband with the ebl is almost a must imo .the ebl is a great product i'm one of it's biggest fans . i do wish it had a safty built in that it would kill spark at a certain airfuel (user programable ) only cuz i run out of fuel an didn't realize it until i watched the data log . no critizem just a suggestion rbob
Old Apr 10, 2012 | 09:37 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
So can i put this WB gauge kit and EBL on my "buy now" list.
Old Apr 11, 2012 | 08:14 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Yes get your EBL now, no on that WB unless you can get an AFR/voltage spec from somebody.
lol
They told you they offer a WB & NB, you gotta find somebody there that knows the product.
Old Apr 12, 2012 | 11:48 AM
EagleMark's Avatar
Or you could buy one that will not only work with EBL but has actual tech support like EBL... not sure what gauge is recomended?
http://www.dynamicefi.com/TT-1.php
Old Apr 12, 2012 | 02:44 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
the tt-1 is the one i'm running with the ebl . it works great plus you can also hook up gauge if you'd like .
Old Apr 14, 2012 | 01:17 AM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Will this link help to confirm if this wb gauge kit works with EBL. Please anybody I hope Rbob can.
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
Old Apr 14, 2012 | 06:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the Innovate WBs work with the EBL systems.
RBob.
Old Apr 15, 2012 | 10:03 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Thank you RBob. Now I have to fix SES light - code 15 ( which I tried for past 3 months without results) and I will be ordering EBL to learn how to tune. Currently LO3 and I am planning to swap L31 and keep TBI.
Thanks again for being so helpful on this forum.
Old Apr 18, 2012 | 11:22 AM
Ronny's Avatar
Something tells me some WB controllers have an audible alarm option.
I run N20 and can monitor the A/f in my data logs. Never got too crazy with lean A/F as I started out filthy rich day one and snuck up on it..
I can see if you are under load and the A/F is very lean bad things happen. But the commanded PE A/F is driven off the VE tables so if you are good with the BLMs PE ( load) should be decent. Now with a power adder i can see benefit.
My EBL does shut down the motor over certain RPMs however if I over rev.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
hectre13
Aug 26, 2015 08:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
