Doing 5 speed swap on 91 z/28 350
Old Apr 21, 2012 | 12:36 AM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
When I bought my car it didn't have an ecm under the dash. I know being a 91 Z, it needs a 7730 ecm and I still have to buy one. What do I need to do to the ecm and wiring harness to make it compatible with the 5 speed swap so everything works like its supposed to? I know nothing about ecms other than they help the car to run. lol
Old Apr 21, 2012 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Doing 5 speed swap on 91 z/28 350
Leave the P/N input to the ECM open and be sure to use a magnetic VSS on the transmission.
Odds are it will need some tuning because of the differences between a stick and and an automatic. But that is up to you as to whether it will be worth the effort.
RBob.
Old Apr 21, 2012 | 09:57 AM
Car: 1991 red Z/28
Ok thanks RBob!! Once I get to that point I will probably be back here asking more questions
Old Jun 2, 2012 | 02:02 AM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
I did a swap from an auto to a t5. I didn't do any ECM changes and it seems to run fine. Im curious if there is any noticable differences between the 2 ecms and what they would be?
I bought the ECM for a 350 auto as it has the esc in there and correct me if im wrong these cars didn't come with a 5speed /350 so I think you would be stuck with the auto ECM either way. Good luck you are going to love it after the swap
xkingcodex
Feb 12, 2020 07:43 PM
69 Six Pack
Oct 5, 2015 07:51 PM
InfinityShade
Aug 22, 2015 08:00 PM
st.evel07
Aug 13, 2015 06:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
