tpi woes
Car: '86 Trans am, and others-too many
Engine: 305 TPI Redone (previous owner)
Axle/Gears: 2.73- YEAH! Ready for the desert
tpi woes
Long time looker, first time poster.
Excellent source of info.
Here it lies, the hopes of getting my 86 Tans Am (305 TPI)rocking for the holiday weekend.
No injection on bank 2. Done all the usuals, injectors ohm at 16.3/5 acroos the board on all 8.
bank 2 (not firing) Pin of connector to pin of connector of alll 4 injectors 4.8 ohms one pin 9 ohms other. to ground 35 ohms and 30 ohms.
Bank 1 (working) 8.8 on pin to pin, 28.1 and 36.1 on pin to ground.
And fuses for injection have power and are intact.
Driving me nuts, fresh install, finising someone elses project, leaning toward bad driver in comp. Does this stand to reason?
Hoping for a guru to step up, in my hour of need.
Thank you.
Jon
Thank you.
Jon
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tpi woes
welcome to tgo, yes looks like the shorted injectors took out the injector driver 16034984
Engine: Lb9
Transmission: M20
Re: tpi woes
Here is a pretty good deal on a refurbished ecm.
http://www.ebay.com/itm/AcDelco-1619...#ht_500wt_1078
Re: tpi woes
Damn. Thank you for the reply, and recommendation on replacement part. Oh well, no cruisin today, or tomorrow.....
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: tpi woes
Is that a 165 variant?
There is only 1 injector driver in there so if one bank work then it would have to be something in the harness.
Engine: Lb9
Transmission: M20
Re: tpi woes
sorry I read it wrong, must be a bad diode or transistor Q1 ?
http://www.exatorq.com/ludis_obd1/1227165schematic.html
Engine: Lb9
Transmission: M20
Re: tpi woes
Inj.1-3-5-7 D15 Lt. Blu
Inj. 2-4-6-8 D16 Lt. Grn
Like jp86ss said check the wiring too the ecm.
Re: tpi woes
After running around, got back to the house today, and for kicks, checked the local "zone." In amazement, had an ecm somebody ordered last year, and never picked up. No way! Any how, $84, an old ecm I had laying here, and the party begins. . . . .Nope. No fire on pass side.
Would have thought bad wire would have been detected by "ohming" wires, from engine side, shorted, open, otherwise.
Guess I'll have to crack open harnesses, unless somebody else has any other suggestions.
Once again guys, thank you for the help, suggestions, and the time, to help me get my time capsule going.
(even the wife likes the ride, had one when we got together 13yrs ago.)
Last edited by jonnythewrench; May 27, 2012 at 08:28 PM. Reason: gramitical rediculosity
Re: tpi woes
Yessir, is of the 7165 variant.
Re: tpi woes
Anyone else ever open the harnesses on thier 3rd gen. Duct tape on wire gangs? Really? Are you kidding? Guess the general was looking to save some quids. F IT,DUCK IT!
Anyone else have any problems in these areas, such as wher injection wires gang together? Tape deteriorated, but connections "appear" clean. Maybe I'll redo them anyway, solder and seal never hurt anything I know of.
BAH! Time for a couple of cold ones.
Re: tpi woes
Quick late night brain storm. Did find old alarm module under dash. Maybe hack butchered into injection power from fuse box to one of the injector circuits for kill. . . . something else to check tomorrow I guess.
Goodnight all. Tomorrow another day.
Sanjay
Aug 12, 2015 03:41 PM
