WinALDL Knock Counts
Old May 31, 2012 | 10:55 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
This might seem like a stupid question, but what sensor in WinALDL monitors the knock counts on an 870 (1985) ECM?
With WinALDL in 870 mode, the "Spark Counts" table is not available.
Old Jun 1, 2012 | 08:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: WinALDL Knock Counts
The knock counts is not in the ALDL data stream.
RBob.
Old Jun 1, 2012 | 08:25 AM
Car: 1985 Z28
RBob.
How am I supposed to know if I'm getting knock retard?
Old Jun 1, 2012 | 09:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Either patch the BIN's ALDL list to include it. Or use an electrical means. Such as a pulse stretcher and audible or visible alert.
http://www.gnttype.org/techarea/proj...ck/circuit.gif
RBob.
Old Jun 1, 2012 | 09:56 AM
Car: 1985 Z28
Sorry I'm new to this. how would I patch the BIN list?
Old Jun 1, 2012 | 12:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It isn't easy, and so far there isn't any hac's of that ECM's code. In the calibration there is a list of addresses that is used to send data out the ALDL link. They mostly point to RAM variables (RPM, O2, LV8, etc.).
Need to find the RAM location that holds the knock counts, then patch that address into the ALDL table of address.
RBob.
Old Jun 1, 2012 | 01:36 PM
Car: 1985 Z28
RBob.
Wow. So with the 870 ECM there isn't even a way to monitor spark advance? The SAREF column stays at 0 at all times.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
