AUJP1350
AUJP1350
I RECENTLY BOUGHT A 1991 CAMARO CONV I ACTUALLY TOOK IN ON TRADE IT IS IN GREAT CONDITION,BUT I AM HAVING A PROB WITH IT RUNNING RIGHT.. I HAVE TAKEN IT TO 2 MECHANICS BOTH ARE SAYING THE PROM IS WRONG IN THE CAR IT CAME WITH A 305 IT KNOW HAS A 350 BORED 30 OVER, ONE MECHANIC FOUND THTA THE CURRENT PROM IN THE CAR IS FROM A 3.1 CORSICS..LOL AND HE DID SOME RESEARCH AND THINKS THAT HE FOUND THE # OF THE PROM I MIGHT NEED, ''AUJP1350'' BUT CANNOT FIND ANYWHERE. MY OTHER MECH SAYS IT WOULD PROBABLY BE EASIER TO JUST FIND A NEW TPI WITH THE ECM AND THE PROM THAT ALL MATCH... CAN ANYONE HELP ME WITH THIS ISSUE OR POSSIBLY GIVE ME SOME ADVICE...
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: did chevy ever put a 5.7L in z28?
Welcome to the boards. Your best bet would be to find someone who is selling a prom or ECM in the classified section on this site. If you need to know exactly which prom you need then start your own thread in the TPI sub-forum.
I know your still most likely learning how to use this site but for future reference, posting on a thread that is from 2001 is'nt the best way to get an answer. As I said though, welcome to the boards and good luck with your car.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: AUJP1350
the aujp is for 90-92 tpi speed density acdelco /gm part number 16151348 I have a couple of them. Thes were use in the 1227730 ecm 5.7L tpi automatic 700r4. There are others that will work anjf
