Need help with scanner readings 85 TPI
Old Jun 27, 2012 | 01:41 PM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
On my 85 Iroc tpi Im getting a code 23 mat sensor. So I hooked up my scanner to see whats goin on. Key on engine off mat showed -40 coolant temp was 90 degrees. Within 2 mins after engine on went to 33-35f. After 10 mins it was at 125. Does that sound like a bad sensor? And my block learn was at 108 and my integrater was between 98 and 104. My car has always ran rich but i used to have those numbers in the 115-120 range. What could be causing this? That mat sensor? My car still feels like it runs good. Any input would be appreciated. Thanks.
Old Jun 27, 2012 | 02:08 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help with scanner readings 85 TPI
Bad sensor and/or connector for it. The -40* reading is the same as if the sensor was unplugged. Look for corrosion on the sensor terminals and the connector.
RBob.
Old Jun 27, 2012 | 02:42 PM
DAVEY420's Avatar
Car: 85 IROC Z
Thank u. Do u think it could be dumping more fuel in because its thinking its cold? Thus causing my weird block learn and integrater #s.
Old Jun 29, 2012 | 10:00 PM
EagleMark's Avatar
Yes, common problem with bad sensor reading cold. Cold = choke/more fuel.
gta90
Sep 15, 2015 04:00 PM
Electro_X
Aug 19, 2015 07:59 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
BOOT77
Aug 10, 2015 12:20 PM
