Bad ECM or Memcal
Old Sep 3, 2012 | 04:06 PM
moneyman380's Avatar
Car: 1991 Z28
Bad ECM or Memcal
Let me start off with my setup. I have a 91z 355 superram tpi, nothing on the moter is stock. I have been burning my own eeproms for awhile then i upgraded to a moeates Ostrisch 2.0 and his usb aldl connector.
Problem is i cannot connect my laptop to the 730 ecm though the data port, nor can i pull any codes from the ses light. All the ses light will do is stay on with the key on and while the engine is running. No codes, not even a code 12 will come up. I have no speedo, and its seems to be only running in limp mode. Everything seems to working right with the Ostrisch, being able to upload new bins to it and communicate with the laptop. Im lost as to wether this is a ecm issue or memcal or something else. Oh i do have three ecms that i did swap out and had no change so its kinda. Any ideas please, id hate to throw money at a ecm or prom and not really need it.
Old Sep 4, 2012 | 08:02 AM
EagleMark's Avatar
Re: Bad ECM or Memcal
Upload bin to emulater, Verify then click emulate. Check engine light should then come on, blink and stay on till engine started.
Also have to change Mask ID to AA to disable checksum.
HTH!
Old Sep 5, 2012 | 03:05 PM
Car: 1991 Z28
I changed the chip code mask from 141 to aa and it says it's emulating now in the bottom left corner on Tuner Pro RT. But it still will not connect through the aldl port. JUST SAYS DA connecting and it just sits there. Any other ideas ?
Old Sep 7, 2012 | 01:54 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
test the orange wire at the ecm labled BA8. That is the serial data line from the ecm to the c207 connector and then it goes straight to the ALDL connector. Test to see if you have closer to 5volts on that line.
Old Sep 7, 2012 | 08:41 PM
Car: 1991 Z28
I performed the test that is in the gm service manual and both connections checked out ok.
Old Sep 8, 2012 | 08:05 PM
Car: 1991 Z28
I found the problem, ended up removing my ostrich emulator and replaced it with the factory EEPROM. Still would not throw a code 12 while jumping the aldl port, so I plugged in a entirely different memcal ( was for a v6, why I didn't before) and she flashed the check engine light code 12. I did not have a chance to connect my laptop to see if the USB data link would work now though. But I guess I'm buying a new memcal
Old Sep 16, 2012 | 03:22 PM
amyz28's Avatar
what is a memcal? my 86 iroc flashes ses and runs spluttery/loses power when the light flashes (its very intermitant) runs perfect wen nor flashing, cand get any codes just utter randomness very much lke theres a broken wire, been told to replace ecm, ive changed 02, plugs leads rotor arm coolant temp and thermostat (as also has overheatin prob!) im over in scotland and not many guys will wrk on the car :/ its had this prob and been off road for a year nw heres a vid of it, any help appreciated
Old Sep 17, 2012 | 10:48 AM
ninetyone's Avatar
Axle/Gears: 3:42
http://www.youtube.com/watch?v=InNYu...3&feature=plcp
When you first turn the key to the "on" position. The check engine light should flash once very quickly and then remain solid. That is a normally functioning memcal. If it doesn't do this then you probably need a memcal.Your SES light bulb could be bad too,but it's rare. Ecm's are easy to find. Looking at $25 from a junkyard.
skeltor
Feb 2, 2016 10:37 AM
88rscamar0
Sep 23, 2015 09:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
RyanJB
Sep 2, 2015 01:27 PM
