TunerProRT 5 files for 1990 7730
Old Sep 29, 2012 | 09:03 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Hello,
It's been a few years since I hooked up my ALDL stuff and I was wanting to do so again. I downloaded a newer version of tunerpro (5) than what I previously had. It wants XDF and ADF files which are different from what I previously used.
Can anyone tell me where to download the proper ones for a 1990 5.7 IROC with a 7730 ECM. The links from the tunerpro site seem to be for the older ADS and ECU files which don't seem to be compatible.
I'm probably doing it all wrong, so if someone could kindly point me in the right direction, I'd sure appreciate it.
EDIT: I have the moates ALDL thingy by the way.
Old Sep 30, 2012 | 06:18 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: TunerProRT 5 files for 1990 7730
I know somebody knows where to get the files I need. Can anyone help me out please?
Old Sep 30, 2012 | 07:36 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
The XDF files are the same as the ones used in previous versions of Tuner Pro. The ADX is different though, and you can import your ADS into ADX format within Tuner Pro RT V5, or you can find some that have been created by someone else.
We have a bunch at www.gearhead-efi.com, for all sorts of applications.
Old Sep 30, 2012 | 09:35 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Thank you, I downloaded them from your site. It's been so long that it's confusing, but I'm starting to remember how this all works I think. Now I just need to hook it up and start tinkering. I want to check out my TPS. The car has been a little jerky when first applying the throttle; I want to make sure that it's not noisy or with dead spots. Fuel mileage has been down too, so I'm concerned about the O2 sensor. The parts in question are the factory originals so..... Thanks again, I appreciate the help.
Old Sep 30, 2012 | 09:40 AM
EagleMark's Avatar
Here's the newest ones JeepsandGuns has been working on, they have not made it to the info thread yet.
http://www.gearhead-efi.com/Fuel-Inj...Information-8D
File Type: zip
Old Sep 30, 2012 | 10:02 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Thanks again, I'll give those a try.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 2, 2015 09:12 AM
