Esc 305 or350
Old Oct 12, 2012 | 10:13 AM
testiculese's Avatar
Esc 305 or350
I,ve done a lot of checking and just can't seem to find an answer.
Question:
How can you tell if that white piggyback board on the prom unit (the ESC module) is fo a 305 or 350? Is there a way to decipher the numbers printed on it or a data base to look it up in. I got whats supposed to be a 350 prom from fleabay and there are no original stickers on it. I dont want to put a prom with a 305esc in my 350.
The number on the esc is 1J9306.
Old Oct 12, 2012 | 11:55 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Esc 305 or350
The 1 I think is the production series or place of production, the J is for 3.1L 60 deg V6, both NA and Turbo. the 9 is the year 89 the 306 is the 306th day of the year.
Old Oct 12, 2012 | 12:11 PM
Engine: Lb9
Transmission: M20
Re: Esc 305 or350
There was a memcal on ebay recently that was stated it was from https://www.affordable-fuel-injection.com/
I informed the seller it was not a v8 memcal it was a modified v6 so the knock sensor will not work. he didn't seem too car too post that information. There will be a jumper installed to get the cylinder select correct too a v8 form pin 56 to 62.
Old Oct 12, 2012 | 02:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Esc 305 or350
To ID the knock filter need to measure the resistance between two of the pins/legs. See the picture, lower left pin (2nd one in) and the top center pin. The pins/legs have the white paint dab next to them.
An L98 filter will be 18K ohms
An LB9 filter will be 14K ohms
Moving to DFI & ECM board...
RBob.
Old Oct 12, 2012 | 02:21 PM
Engine: Lb9
Transmission: M20
Re: Esc 305 or350
the v6 one will show around 46.8K pin 31 to 48 like rbob showed the picture of.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
