ECM swapping
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
ECM swapping
Im running an 87 TPI 350 auto GTA currently using EBL converted to MAP.
Is it possible to use a stock ECM from a 90-92 instead of the EBL?
Reason being, Im considering selling my car and would like to keep the EBL.
Car: check
Engine: check
Transmission: check
Re: ECM swapping
If you are currently using the EBL Flash ECM, will need to add a third ECM harness connector and re-pin the two connectors into three connectors.
If you are using an EBL P4 Flash ECM it is plug & play with the '90-'92 f-body EFI harness.
Since the engine/drivetrain is modified, maybe sell the car with the tuned EBL. Then just get another one for your new car.
RBob.
RBob.
