Date logging, BLM too low??
Old Nov 23, 2012 | 12:03 AM
88I-ROC's Avatar
Car: 1988 Camaro Iroc-Z
Axle/Gears: 3.08
Hi all, I did some logging today with datamaster, and I noticed that the long-term C count(BLM) was fairly low, I was wondering if someone knows what can cause that, and what do I need to look for in order to fix it, besides burning a new prom. I added an image of the data logging, so you can see the data, maybe there is something else that is not right that I should know about.
The car is mostly stock 305 with 180 stat and 180 fan switch, and gutted MAF.
Thanks in advance.
Old Nov 23, 2012 | 11:12 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Date logging, BLM too low??
Thanks in advance.
any codes? an adjustable fuel pressure regulator and lowering fuel pressure helps a little, otherwise you need a tune.
Old Nov 29, 2012 | 10:10 AM
Ronny's Avatar
Are you suggestion cross counts are BLM? I was not aware of a relationship.
there is I found this in stickies from RBob
" The INT is updated whenever an O2 sensor x-count does not occur within a certain time frame."
Old Nov 29, 2012 | 11:19 AM
88I-ROC's Avatar
Axle/Gears: 3.08
Thats what I understood from reading few threads about the subject over here.
Long term cross count=BLM
Short term cross count=INT
But anyway, I got bigger issues with the car right now, but that would be belong to a different thread...
Old Nov 29, 2012 | 12:45 PM
Ronny's Avatar
This is a good read on all that is involved with NB02 feedback.....
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Nov 30, 2012 | 07:41 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Everything seems to point to a motor running rich. The BLM is bottomed out and it looks like the INT isn't high enough to pull it up. I'd look at adjusting my IAC counts at idle. 54 seems a bit high so you could start by adjusting the Min Air.
L98GTA87
Oct 19, 2015 10:43 PM
327IROC85
Sep 23, 2015 12:11 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Thirdgen89GTA
Sep 12, 2015 08:39 PM
