Precautions When Changing PROM
Are there any precautions I should take when changing out a PROM? I will obviously disconnect the ECM from the harness but are there static discharge issues or anything else I should be concerned about?
Larry
Larry
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Precautions When Changing PROM
Disconnect your battery and disconnect the ecm. Esd can cause ecm and eprom damage so a ground strap is a good idea but most people don't use them.
Transmission: 5-speed/T-5
Honestly, all I make sure of is that the engine is off.
I only disconnect the ECM sometimes to clear any BLM history that might be stored.
Best preactice is as suggested to disconnect the battery first, but I haven't found it necessary in the couple of decades I've been playing with EFI. *shrug*
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Use an anti static bag to carry the prom to your car. Make sure you disconnect the negative battery cable and touch the body of the car with your hand before you touch the chip to install it.
Car: 1985 IROC-Z28
Engine: LB9
ignition off and you're good to go. if you really feel like static will be an issue(worse in some climates than others), then hold a hand on a grounded surface before you start handling anything sensitive. if that doesn't discharge you, not much will.
for those of us with underhood ECMs, this is a lot easier to remember/do.
Car: 1989 Iroc-Z
Engine: TPI 350
Axle/Gears: 3:27's
Mechanic once told me to always wear some rubber gloves because even touching the carpet can cause static....
Sanjay
Aug 12, 2015 03:41 PM
