How do i make VSS work after ECU removal
Old Feb 8, 2013 | 12:12 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
I chucked the Ecu from my 88 firebird but left the 4 out buffer plugged in. What do i need to do to get the speedo to work again. It used to work before. Mabey a ground or something?
Old Feb 8, 2013 | 04:09 PM
bonesbrakr's Avatar
Re: How do i make VSS work after ECU removal
If i remember right you need to ground the black wire with white stripe.
Old Feb 22, 2013 | 01:45 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Buy a Dakota digital Speedo healer/programer. I had to chuck the old VSS when I swapped in the 6 speed. There cheep and pretty accurate!
Old Feb 22, 2013 | 02:14 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
actually i just redid the black/white stripe ground. no need to waste money on some electronics
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
mizz0313
Aug 12, 2015 06:45 AM
3rdgenparts
Aug 8, 2015 07:09 PM
